Server Exiting when MatOUT is deleted
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
sinesium
When Material Output in Material Nodes is deleted by user when LiveView is active then Server stops its work and closes.
Be patient for me, please. I am new here.
I can't reproduce it... Could you give me the scene where it happens?
sinesium
Hi
It happend in ver 11.11 that I had to return from the new release because of no image in Full Render problem in new version.
In ver. 11.14 this problem does not appear.
If you will be able to fix the problem with Final render quite soon than I will not back to previous version ( now I have 11.14 to test topic problem)
and I will wait for new release.
And look at the reroute point problem, please.
viewtopic.php?f=114&t=57819
When reroute is in use in the path of Projection ( i.e.) Box then it does not work at all ( UV mapping is using as default instead ).
Reroutes are not supported by current plugin version.
I will look into it later.
Return to “Bug Reports”
