C4D Node editor issues
A forum for discussion, development and support, including subforums for discussion for various plugins for octane render and 3d the relevant animation packages
Broccoli
So I am having a weird issue with the node editor. When I change A material to glossy or spectacular it does not show the additional attributes in the node editor. Anyone have this issue before? Am I missing something simple? Never had this happen before.
Also I updated to the most Recent version of Octane standalone and the c4d plugin with no prevail.
Image of my issue
http://imgur.com/a/SMtm2
Running r17.055
C4d Plug-in version 3.04.5
Standalone version 3.04.5
Windows 10 64bit
Close and open NE when this happen. I can't reproduce this issue on me.
Broccoli
No luck opening and closing the Node Editor. It also persists even if i do a full system restart. Nothing I do seems to make it start working. I have even tried making a new project and the issues persists in the new project as well.
What happens in material editor if you change type? Can you save a scene with diffuse+glossy+specular materials? I wiah to check it. Thanks!
Broccoli
In the material editor it changes for me just like it should. It's only when I go to the node editor that I see the issue. the link is for a scene file that has one of each put on a Sphere.
https://www.dropbox.com/s/qidxuv8hqscm1 ... s.c4d?dl=0
It's working fine on me as in capture. Can you confirm that's not like this on you? It's not making any sense on me. There is not changes in node editor which can affect this since a few versions. It may be worth to check your plugin files. Delete all content and make a new extract from latest version.
2016-12-06_00-21-02.mp4
(5.86 MiB) Downloaded 18303 times
Broccoli
I will try that and report back. When I do what you did in your video it does not change in the node editor area.
Broccoli
So after getting back to the issue I have found it is on both of my machines. It definitely happened when C4d ran the most recent updates. In the video you posted was that r18 or r17? I am running r17.
Scratch that. Back tracked the plug in and it fixed my issue.
Return to “Plugin Discussion/Support”
