OctaneRender® for Maya® 3.04.5 - 9.5 Win [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine.
  • Improved material converter to support imported FBX case.
  • Minor fixes and improvements...
DOWNLOAD
OctaneRender for Maya 3.04.5 - 9.5
OctaneRender for Maya DEMO 3.04.5 - 9.5
viewtopic.php?f=24&t=57660
Yours,
The OctaneRender™ Team.
renmaxhb
Great!! :lol:
Jolbertoquini
Hi Jim,
Thank you for the update, I left a message about the virtual material we have issues when we do a batch render on the Farm, everymachine render a different results we have to use aways the same machine (big problem for us when we render big animations) and also every version of the scene is changing is not stable to be use on production If you could make a fix on the virtual material to aways be the same result in different machines and versions of the file would be great.
EDTIT: I also deactivacted the option “Non-permanent object material” .
Best,
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
mrfactory
hello, we have an interface problem with MAYA 2015, with the latest stable version.
http://82.144.5.101/file/interface_plug_octane_maya
All texts are crowded and impossible to read/use.
teammach
same here, addribute editor in maya 2015 is messed up once you select an object. Overlaping typo.
