error log
hrlv
Hello. So i coudnt install the software in my 2015 mackbook pro, and im trying to do it on my late 2012 imac. the standalone version works and i get no errors however in the cinema4d plug in i got this log:
Probably lack of memory in my imac? is there a way to solve it? thank you so much.
- EXPORT LOG ---------------------------
Export materials time= 17.575 ms
Collect objects time= 6.201 ms
CUDA error 2 on device 0: out of memory
-> failed to allocate device memory
device 0: detected an error on render device! trying to recover...
Mesh creation time = 22.978 ms.
Triangles:0 Disp.triangles:0 Hairs:0 Meshes:0
VRAM used/free/max:2Kb/187Mb/511Mb
Out-of-core used:0Kb total used RAM:5.135Gb
Total export Time = 82.027 ms
device 0: the device failed immediately after the recovery -> giving up and switching the device into error state
<<< Render failure detected!!! >>>
Please check render statistics to solve the problem.
Device:0 TotMem:511Mb rtData:2Kb film:0Kb geo:0Kb node:0Kb tex:0Kb unavailable:285Mb
Hi hrlv,
unfortunately, the internal GPU of your iMac is already working for the system and the monitor, leaving few VRAM to work with OctaneRender. Beside adding an external GPU via Thunderbolt as explaned in this discussion:
viewtopic.php?f=9&t=43439&start=170#p276341
the only solution is to try to keep your geometry as low as possible and active the Out of core option for moving all the texture in system RAM instead of VRAM:
https://docs.otoy.com/manuals/products/ ... t-of-core/
calus
That's very strange, this Topic also appear in the Help/tutorial section of the Maya Forum. viewforum.php?f=126
It seems there's a bug in the Octane forum section management...
Pascal ANDRE
Thanks Calus! There should be an issue about management. I suppose this is not a BUG or TUTORIAL post. So i'll delete this topic soon.
