Hi
Nobody have problem with deamon render ?
I can't render on two pc, I get error : 729 on device 0 (and other) : unspecified launch failure and other errors...
A simple cube can't be rendered.
error with daemon 3.04.3 - 4.25
- paride4331
Hi HHbomb,
have you verified OctaneSA work on your slave?
Regards
Paride
Regards
Paride
Hi, thanks Paride for answer.
Very strange :
I (re) install octane and max plugin on main computer, (re) install octane on second computer. Open octane SA on second computer : ok----> deamon render failed
I open in SA sample scenes on second computer and play a bit.
Then I tried deamon render again, and now it works fine ( for the moment )... Don't really understand, but very happy
Very strange :
- paride4331
Hi HHbomb,
Keep us posted!
Regards
Paride
Keep us posted!
Regards
Paride
Okeey.... Crash again. Was working but now failed again.
I have done the following :
Install deamon on second computer for one video card. and test if rendering is ok.
I tested one card after the other, and discovered that third card fail.
Then I install deamon for 1,2,4 cards and all is ok ( for the moment )
The failing card works on some scenes, but when making lots of instances it make an error.
As I wrote a lot of times some times ago in the forum, It would be great to have Tools for testing cards and resolve some of the problems as octane is based on video cards...
- paride4331
Hi HHbomb,
Could you share some information about your slave, regarding hardware configuration and Os?
Could you use the octane_log for more information on your issue?
To make this, you have to copy the file "octane_log_flags.txt" Standalone main root directory
and "octane_daemon_log_flags.txt" into the Standalone directory on the slave computer.
remember to enable the permissions to write Octane folder.
e.g. OctaneSA select folder> Rightmouseclick> properties> security> ...
Placed after the "octane_log_flags.txt" and "octane_daemon_log_flags.txt", restart and generated the issue.
Octane will create "octane_log.txt" files, with information about your issue.
attach these files to better understand what happens please.
Regard
Paride
Regard
Paride
- Attachments
- octane_daemon_log_flags.txt
- (98 Bytes) Downloaded 140 times
- octane_log_flags.txt
- (106 Bytes) Downloaded 148 times
