OctaneRender® for Maya® 3.04.4 - 9.1 Win [OBSOLETE]
Sub forum for non-production plugin releases
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine.
  • A couple of fixes and improvements...
DOWNLOAD
OctaneRender for Maya 3.04.4 - 9.1
viewtopic.php?f=24&t=57372
Yours,
The OctaneRender™ Team.
gah5118
Is the new version now going backwards and dropping all functions that were being reveled back in June? For example, direct link into octane's native node editor.
Windows 8.1 | i7 950 | GTX 780ti | 24gb ddr3
Refracty
seems so, but it is a good decission to put something (stable) up with V3 as fast as possible
The new architecture will be developed simultaniously.
Jolbertoquini
Refracty wrote:seems so, but it is a good decission to put something (stable) up with V3 as fast as possible
Personally for us a new architecture is not the best choice when we have a lot Artists, This is money cost cause we have to training then. If we have both solutions then is fair enough for everyone.
Jim I tested this version and is looking better thanks for all.
Just one thing I'm not using this feature but I realize on hypershade the "material viewer" is looking not correct the image are clamped and the HDRI are looking wrong "gamma" everything seam over exposed.
like if double gamma correct a hdri on sunsky, also the option "OFF" is broken.
The "Extra Atribute" options are weird showing on the wrong place called "Freeze" and not on "Extra". see on image bellow.
Thanks again guys for all your efforts.
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
renmaxhb
hi,Jolbertoquini
what is you maya vision and your GPUs? I test it in maya2015 GTX780TI,always crashed when load the plugin 3.0. Too many jobs to render,i cannot test other maya vision.
calus
Jolbertoquini wrote: Personally for us a new architecture is not the best choice when we have a lot Artists, This is money cost cause we have to training then.
I guess you're mixing up "Architecture" and "UI", two plugins can have the exact same UI with two very different architectures.
The aim of the "big refactoring" (failed attempt apparently) was to get rid of the limitations of the current implementation of the plugin,
but in theori could have the exact same UI. (but would be a shame to not take the opportunity to get rid of the UI flaws).
The nodes and attributes matching exactly the Standalone ones, would just have been an happy side-effect of the refactoring,
(as in Maya, internal code structure is visible through nodes)
There was just no UI developed yet in the non-functional somewhat refactored pre-alphaV3 we have tested ;)
Pascal ANDRE
calus
@JimStar,
"Hair W min" and "Hair W max" attributes on all transforms should be set to non-keyable and hidden for the channel box,
(they will stay keyable in attribute editor).
Pascal ANDRE
calus
@JimStar,
As the particle/instancer motion blur now works, too bad there's still a problem for nParticle,
the check in Octane to see if particles have a cache is wrong (only checking for legacy cache, should look for nCache).
In fact I workaround this bug adding a fake legacy cache on top of the nCache to render nPartcle motionBlur.
So that's just the wrong check for cache that prevent the nParticle motion blur to render, throwing a wrong warning message about missing cache.
Also varying particle number still loose track of the particle ID resulting in a wrong motion blur. (cf. bug report section).
Pascal ANDRE
gah5118
if the limitations are going to be the same with no access under the hood... then I'll continue to keep the plugin "on the shelf" and keep using the stand alone. As for my company... we will forgo purchasing the plugin.
was getting excited to see where it was going. It's a real shame to see.
calus
gah5118 wrote:if the limitations are going to be the same with no access under the hood... then I'll continue to keep the plugin "on the shelf" and keep using the stand alone. As for my company... we will forgo purchasing the plugin.
I think Goldorak still keeps in mind the "big refactoring" of the maya plugin for Octane 3.1,
this make sens as OSL will introduce lots of potential improvements.
Anyway this is now a separate development branch as it should have been from the beginning,
I don't know when/if it will be active again.
The benefit is, in the meantime we have a stable V3 plugin, based on V2 plugin implementation and its limitations yes,
but usable now instead of just waiting one more year.
Pascal ANDRE
Return to “Testing Releases (Non-Production)”
