OctaneRender® for Maya® 3.04.4 - 9.0 Win [OBSOLETE]
Sub forum for non-production plugin releases
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine.
  • Implemented the full support of 3.X engine features.
  • Fixed some previously reported bugs.
DOWNLOAD
OctaneRender for Maya 3.04.4 - 9.0
viewtopic.php?f=24&t=57372
Yours,
The OctaneRender™ Team.
renmaxhb
where is demo vision?
BK
Hi renmaxhb :)
OctaneRender® for Maya® v3 Demo will available to download after this version is stable enough.
We really appreciate for your patience.
Kind Regards
bk3d
renmaxhb
BK wrote:Hi renmaxhb :)
OctaneRender® for Maya® 3.04.4 - 9.0 Demo will available to download in few weeks time.
Thanks,I have two renderfarms with lisence to output,and work on other machine with demo vison :)
BK
Nice !! we have started working on making Octane stable and it will ready for you :)
Kind Regards
bk3d
Jolbertoquini
Hi Jim and Kai, BK,
Thanks for the updates is pretty stable and is working my older scenes, personally we love this version cause is the same way as the OC2 plugs we don't have to training our team again, for this new way to workmade by kai before, for this would take us a huge time to get things right with our Light artists. Appreciate your work for that.
Just would be good to have a quick manual how to use Fluids with octaneVolumeMedium?
Also please let us know about support on XGEn, Bifrost, MASH and also a longtime a go I gave Kai the contacts of the guys from Ephere for Ornatrix they was pretty motivated to add a support for Octane.
Thanks again for the Update.
Best,
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
ivankio
Will 3.x go forward with this 2.x based branch dropping the node based one?
How can I set it to render to texture?
Just reporting: I'm getting some errors that are messing the Attribute Editor in 2017:
// Error: line 1: Found no attribute match for "perspShape.octSwapEyes" //
// Error: line 1: Found no attribute match for "perspShape.octBakGroupId" //
// Error: line 1: Found no attribute match for "perspShape.octRevBaking" //
// Error: line 1: Found no attribute match for "perspShape.octPadding" //
// Error: line 1: Found no attribute match for "perspShape.octTolerance" //
// Error: line 1: Found no attribute match for "perspShape.octUseBakPosition" //
// Error: line 1: Found no attribute match for "perspShape.octCamBfCulling" //
// Error: line 1: Found no attribute match for "perspShape.octUVset" //
// Error: line 1: Found no attribute match for "perspShape.octBakUvBoxMin" //
// Error: line 1: Found no attribute match for "perspShape.octBakUvBoxSize" //
// Error: line 1: deleteUI: Object 'octSwapEyesOctColumn' not found. //
// Error: line 1: deleteUI: Object 'octBakGroupIdOctColumn' not found. //
// Error: line 1: deleteUI: Object 'octRevBakingOctColumn' not found. //
// Error: line 1: deleteUI: Object 'octPaddingOctColumn' not found. //
// Error: line 1: deleteUI: Object 'octToleranceOctColumn' not found. //
// Error: line 1: deleteUI: Object 'octUseBakPositionOctColumn' not found. //
// Error: line 1: deleteUI: Object 'octCamBfCullingOctColumn' not found. //
// Error: line 1: deleteUI: Object 'octUVsetOctColumn' not found. //
// Error: line 1: deleteUI: Object 'octBakUvBoxMinOctColumn' not found. //
// Error: line 1: deleteUI: Object 'octBakUvBoxSizeOctColumn' not found. //
GTX 1080 8gb, GTX 970 4gb, I5 4590, Z97-E, 32gb RAM, Win 10 64bits, Octane for Maya
Jolbertoquini
Hi Guys,
Quick question the medium nodes doesn't work with octaneSunSky when I try to plug "out medium" I'm not aloud but the "scattering" is connecting but not working.
Could you send something about this, like how to use.
Same for mesh or fluids...I guess is not finish... other option so far is working Portal lights is a bug in the actual standalone., I think would be fix next realease.
Best,
JO
Return to “Testing Releases (Non-Production)”
