OctaneRender® for Maya® 2.26.1 - 7.20.5 Linux [LAST 2.X]
Locked
Maya® Version Requirements
This release will work with Maya® Version 2017 64-bit on Linux operating systems.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine.
  • Fixed a particle system export bug.
  • Fixed a particle system crash.
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - 7.20.5 Linux
viewtopic.php?f=24&t=57368
Yours,
The OctaneRender™ Team.
Locked
