How to animate octane's different values, in Poser?
Tigersan
Is there a way to animate Mix node's value from poser?
I need to animate mix amount on two different displacement
maps, so that one slowly changes into the other one as the
animation progresses...
My Artstation profile: https://www.artstation.com/tigersan
Software: Poser 11 Pro, Octane Studio 2020.1.5.104, Adobe Suite
My RIG:
Operating system: Windows 10 Pro 64
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
HDD: 2x WD Gold 7.68TB U2 NVME
Displacement maps need to be directly plugged into the displacement pin of a material - you cannot mix or modify displacement Image maps with the current version of Octane. Pls see the link in my signature for details.
Tigersan
face_off wrote:Displacement maps need to be directly plugged into the displacement pin of a material - you cannot mix or modify displacement Image maps with the current version of Octane. Pls see the link in my signature for details.
You can, I have set it up, you can't connect the mix node to the displacement itself, but you can connect it
to the displacement texture and that's what I mean.
My RIG:
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
I would doubt it would render the displacement in that case. Can you problem a screenshot of the material tree for that material showing the displacement nodes pls?
Return to “Poser”
