I installed poser NOT in the traditional directory -- as someone advised better not to { to avoid a host
of issues }
However, I installed octane 3 to this new directory. And I don't see it in Poser.
1. What is the install path{s} for octane 3?
a. can I move the files to this new install path { if wrong } -- or have to reinstall over old one?
2. Does it show in the same render list as 2?
i see it in the new folders, but apparently not installed correctly
thanks
where is Octane 3 ?
1 Do you normally install to the poser location? { In this case c:poser ? }
or move them? { there is no c: programs > smithmicro , because I didn't install there. }
2 I dont see an octane.exe anywhere. Is that the name of it?
3 I have files in c: poser> runtime> python > addons > octanerender for poser.
and
c: poser> runtime> python > addons > octanerender for poser > 3-64.
such as dll. and octane.dat
thanks
and
thanks
1: personally, I have separated/dedicated hdd's for various things. The operating system (Windows in my case) in on one, the 3D stuff is on another and for all the other software I install(ed), I use yet another one.gold wrote:Hi,
and
thanks
So I do not have Poser installed on C:
2: I was talking about the file, you can download at the fist post of this topic:
viewtopic.php?f=45&t=56137
Windows OctaneRender for Poser 3.4.3.79 (64 bit) is the lated (test) build.
When executing this downloaded *.exe file, the installation wizard will ask you where you want to install the plug-in to. So simply use the root folder of the Poser installation, where you want to use the plug-in from.
I have a parallel installation of PP2014 and PP11. And in both "Poser installation folders" I installed the OR plug in.
3: my installations are then:
...\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser (folder with lots of files)
and
...\Smith Micro\Poser Pro 11\Runtime\Python\addons\OctaneRender for Poser (folder with lots of files)
thanks,
but problems have gotten worse.
I think Octane was installed in the wrong folder for some unknown reason. { Actually the only
path it suggest is smithmicro also - which I wish would also be taken out. }
anyhow - I uninstalled it and now getting a WORSE error. [ before even trying to reinstall.]
ERROR:
the Nividia GTX 880m card can not be removed or deleted { wording not exact }
....... HUH ?......
and THE ENTIRE COMPUTER HANGS now till a forced reboot!
ERROR:
....... HUH ?......
