OctaneRender® for Maya® 2.26.1 - 7.20.1 OSX [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Version 2017 64-bit on OSX operating systems (including and above 10.9).
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine.
  • New 2.26.1 rendering core.
  • Implemented the asynchronous mode for LiveDB/LocalDB dialog. Now you can acquire multiple materials from DB not closing the dialog.
  • Implemented support of different directories for LocalDB data, see the new setting in Octane globals. Current Octane core requires you restart a plugin to see the effect of this setting change.
  • Improved displaying of Octane textures in Maya's viewport.
  • Fixed default passes channels naming. Common layer IDs for multilayer EXRs are now used (same IDs as produced by standalone for multilayer EXRs) if no special names are set by a user.
  • Fixed camera mapping functionality bug (wrong mapping on some geometry types).
  • Minor fixes and improvements...
Installation:
- Just run the autoinstaller file.
DOWNLOAD
OctaneRender for Maya - 7.20.1 OSX
viewtopic.php?f=24&t=57368
Yours,
The OctaneRender™ Team.
nickson
Cheers!
p3taoctane
Thanks you
This is much appreciated
