Animated Texture
jspivey
I'm trying to use the range feature with an image sequence. It's not working. I used both the C4d and Octane image textures and no luck. I can get the animation to play at the start of the project
, but not get the range to work. What gives?
Can you be more informative with a sample scene i can help better. It simply works on me. Also always write version numbers/OS.
jspivey
Thank you for the reply. Here's an example file with a native mat an octane mix material that I'm using the animated texture in the Amount input.
https://www.dropbox.com/s/6434xzwu343k4z5/ex.zip?dl=0
I think it got it to work, but only in "loop" mode. Simple does not work. I also cannot "stretch" the range in any way or it loops infinitely.
3.00 R1.1
R17
El Capitan
Are you still on 3.00.etc version? I think you should follow release threads and release notes. This issue fixed on some version after 3.00.
Change log:
https://docs.otoy.com/#60Change%20log
