OctaneRender™ for Blender 3.04.3 - 11.11 Linux [OBSOLETE]
OctaneRender™ for Blender plugin. Linux x64 version.
1. OctaneRender™ Server
After the server is run - you can start rendering (or open a rendered view) from inside Blender. Before the very first rendering you should fill in the server address.
  • Implemented workaround of Blender bug that led to lost "updated" status for some specific objects when switching frames. Now Octane export should work correctly with curves and curve-modified meshes. (Thanks aLeXXtoR)
You can read about new features of OctaneRender™ 3.0 here:
viewtopic.php?f=33&t=51679
Installation:
- If you need to run the OctaneServer - run it as daemon:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v11.11 Linux
DEMO is available..
Blender Octane Edition DEMO - v11.11 Linux
If you need to see the changelog of current rendering core, or download standalone installer to get network slave and daemon please find it here:
viewtopic.php?f=24&t=57153
Please, if you decided to report a bug:
- Don't post in Blender section the reports about how Octane engine works - use the Octane Standalone forum sections for that.
- Give a meaningful description about what you think is wrong and how to reproduce it (in addition to screenshots if any). I can't solve the "one screenshot" rebuses without any meaningful description...
- If you use Google-translator to post here - check please what you got before posting it, and edit it before posting. Ask your friends to check it if you don't speak English.
