Contant crashes ? octane or my fault ?
jakeamin
Started logging on 05.11.16 17:40:42
OctaneRender 3.03.3 (3030003)
Starting the Octane API twice is not allowed!
--------------------------- EXPORT LOG ---------------------------
Export materials time= 407.997 ms
*** Calculating motion blur on frame:0
TIMES=0 time=5.513 ms.
Collect objects time= 63.167 ms
Mesh creation time = 562.671 ms.
Triangles:0 Disp.triangles:0 Hairs:0 Meshes:0
VRAM used/free/max:350Mb/4.274Gb/6Gb
Out-of-core used:0Kb total used RAM:7.469Gb
Total export Time = 1121.466 ms
CUDA error 719 on device 0: unspecified launch failure
CUDA error 719 on device 0: unspecified launch failure -> kernel execution failed(report)
CUDA error 719 on device 0: unspecified launch failure -> failed to launch kernel(ptBrdf2)
device 0: direct light kernel failed
device 0: detected an error on render device! trying to recover...
CUDA error 719 on device 0: unspecified launch failure -> failed to deallocate device memory
CUDA error 719 on device 0: unspecified launch failure -> could not get memory info
CUDA error 719 on device 0: unspecified launch failure -> failed to deallocate device array
CUDA error 719 on device 0: unspecified launch failure -> failed to deallocate pinned memory
CUDA error 719 on device 1: unspecified launch failure
CUDA error 719 on device 1: unspecified launch failure -> kernel execution failed(report)
CUDA error 719 on device 1: unspecified launch failure -> failed to launch kernel(report)
CUDA error 719 on device 1: unspecified launch failure -> failed to copy memory from device.
device 1: direct light kernel failed
device 1: detected an error on render device! trying to recover...
CUDA error 719 on device 1: unspecified launch failure -> failed to deallocate device memory
CUDA error 719 on device 1: unspecified launch failure -> could not get memory info
CUDA error 719 on device 0: unspecified launch failure -> failed to unload module
CUDA error 719 on device 1: unspecified launch failure -> failed to deallocate device array
CUDA error 719 on device 1: unspecified launch failure -> failed to deallocate pinned memory
CUDA error 719 on device 1: unspecified launch failure -> failed to unregister pinned memory
CUDA error 719 on device 1: unspecified launch failure -> failed to unload module
CUDA error 719 on device 1: unspecified launch failure -> failed to bind device to current thread
device 1: failed to initialize resources
device 1: failed to recover - giving up and switching device to failed
<<< Render failure detected!!! >>>
Please check render statistics to solve the problem.
CUDA error 719 on device 0: unspecified launch failure -> failed to bind device to current thread
device 0: failed to initialize resources
device 0: failed to recover - giving up and switching device to failed
device 0: data texture 4 was not initialized
device 1: data texture 4 was not initialized
device 0: data texture 1 was not initialized
device 1: data texture 1 was not initialized
Export materials time= 403.339 ms
TIMES=0 time=4.684 ms.
Collect objects time= 44.545 ms
Mesh creation time = 612.464 ms.
VRAM used/free/max:0Kb/4.274Gb/6Gb
Out-of-core used:0Kb total used RAM:7.875Gb
Total export Time = 1269.364 ms
Please make this seperation. These are different. Cuda errors. And most likely it's not up to plugin side.
Occurs on deep layer(Renderer side) and you should determine the reason by your self.
Is it a low-resource problem or an object/matrices or texture. Delete some parts of your scene and try until find.
Btw there is something weird in your log: "Starting the Octane API twice is not allowed!"
Propably you have double octane plugin. Pls check this. And try with latest 3.04.3 version.
And last one, don't update your drivers if you're happy with current driver.
jamescombridge
I can confirm that the first error (CUDA 719) was due in my case from having a mesh with dodgy geometry: dodgy booleans & connecting polygons facing different directions etc. Worked fine after it was cleaned up.
jamescombridge wrote:I can confirm that the first error (CUDA 719) was due in my case from having a mesh with dodgy geometry: dodgy booleans & connecting polygons facing different directions etc. Worked fine after it was cleaned up.
It should not crash for this.
