Hello, this started after I downloaded a "preset" pack that had folders with .pst files... I've never gotten a third party library so I don't know what's what. Nothing showed in LocalDB when I put the files in there, so then I went and deleted those files & folders.
After deleting those files & folders, LiveDB now completely freezes Cinema 4D R17 on opening. I tried setting LocalDB to a different folder and it still crashes.
Anyone experience this or have a solution? Thanks.
						LiveDB open freezes R17
Create again the directory.
- richieblac
Okay so I re-downloaded the files & folders (that I do not want) and put them in the LocalDB and LiveDB loads again, no crash. However, the point is that I do not want those files & folders in LiveDB/LocalDB. If I select the folders in LiveDB window and say "Remove" it doesn't work. So what do I do?
						Problem occurs when you delete localdb path and it's a bug on plugin. There is a command to show localdb path. Find and delete files or subdirs not main directory.
