sequentia does not work
Elvissuperstar007
sequentia does not work, I have animated trees, on which they render static, in version 2.25 it worked
I ruined all the work, I have depended on the final scene of the works of the team and that's what I got in the end ((
roeland
If I understand correctly the problem is the noise on the pavement in the foreground? Or is there another problem with the trees?
What are the render settings (mainly the kernel settings and the environment settings), and what type of material is used for the pavement? It will be helpful if you post 2 of the rendered frames showing the difference.
Roeland
Elvissuperstar007
roeland wrote:If I understand correctly the problem is the noise on the pavement in the foreground? Or is there another problem with the trees?
Roeland
it is not the noise!), there are two models by chance in the same coordinates, the wind does not work, standard camera does not understand animation
