Octane C4D - image texture appears multiple times
Sence3D
Hey,
somehow my image texture appears multiple times, i enabled the alpha channel, i tried to increase the size of the image but it didnt work out. :(
so if anyone knows a solution, please let me know.
thanks
Hi Sence3D,
you have to change the Border Mode inside the Imagetexure node.
With the default mode Wrap around, the texture is tiled over the mesh:
based on your alpha image, you can chose different settings, in this case White color is the right one:
Sence3D
Hey bepeg4d,
thank you, but already found out that the texture appears on the other side of the glass because of its thickness
thanks anyways
