Juanjo...the octane marble node (for example the Power Number) would not be updated if i animate them. not with update scene and update material/ not with update only material in enabled obj. parameter / and also not with full scene reloaded...
only if i change the power from the marble node if the IPR is active it would change in realtime...have you any idea what the problem is?
snip lwguru
octane marble node problem
- LightwaveGuru
- Contact:
http://www.neotek.laboratories.de or http://www.youtube.com/c/Lightwaveguru or http://www.facebook.com/safarifx 4x Titan X 12 GB watercooled / 6x 2080 ti air cooled / 2x 980 ti watercooled
- LightwaveGuru
- Contact:
Problem is located. if you resize a model up to factor 100 the marble node not would be updated. with the original size from the object it is in function! problem is solved!
snip lwguru
snip lwguru
