Failed to deallocate device memory
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
peteg
I've been running into an issue with render failures when trying to animate a cloner with a child lathe. The attached reference has the cloner object heading animated, but I've run into the same problem in other setups where the transform scale and other values are animated. It seems to show up a lot of the time when the parameter starts at 0 and goes up from there. The reference scene is a stripped down example that replicates the failure from other scenes I've had. Let me know if I can send any other info your way.
Peter
Crash Log:
https://dl.dropboxusercontent.com/u/105 ... 201734.log
Reference Scene:
https://dl.dropboxusercontent.com/u/105 ... e%2004.c4d
Windows 10
GTX980TI x2
32GB
375.63
3.03.4
3.03.3-R1
Cinema4D R18
Thanks for very detailed information and scene. I'm gonna check asap.
Return to “Bug Reports”
