Node Wrangler in Octane
TomiFoldes
Hey Guys,
do you know if there's anything similar to blender's node wrangler option in octane c4d?
(It's a hotkey option that connects just the currently selected shader network to the object, so it's easier to see/edit noises..etc)
Thanks!
Not available. But It doesn't mean that will not have similar improvements.
Terryvfx
I asked for this once, it's amazing, I found a way to get a similar feature if you go to the multipass go to material passes and activate the relevant filters like that you can get an output of the actual texture you are using to drive roughness for example, not quite like the Node Wrangler but pretty close.
