OctaneRender™ =VR= for Blender 3.03.4 - 11.3 Win [OBS]
This is a TEST version. It may have some bugs, please don't use it for production. Please report the bugs in a Bug Reports section of Blender forum.
OctaneRender™ =VR= for Blender plugin. Windows x64 version.
This version needs an active subscription! If you have a standard license - please use non-VR version instead.
1. OctaneRender™ Server
To stop the server - just right-click its icon in the tray.
After the server is run - you can start rendering (or open a rendered view) from inside Blender. Before the very first rendering you should fill in the server address.
  • Blender's edge creases are now supported by Octane's OpenSubDiv.
  • Reworked Octane export processing. Now this functionality is nicely integrated into the standard Blender's "Export" menu. The "Export scene" setting is removed from main UI. No extra image files are created from now on during export.
  • Textures node graph is now created with Octane image texture by default if current renderer is Octane.
  • A couple of minor fixes and improvements...
You can read about new features of OctaneRender™ 3.0 here:
viewtopic.php?f=33&t=51679
Blender Octane Edition - 11.3 (2.78)
Octane Server =VR= - 3.03.4 - 11.3
If you need to see the changelog of current rendering core, or download standalone installer to get network slave and daemon please find it here:
viewtopic.php?f=24&t=56093
Please, if you decided to report a bug:
- Don't post in Blender section the reports about how Octane engine works - use the Octane Standalone forum sections for that.
- Give a meaningful description about what you think is wrong and how to reproduce it (in addition to screenshots if any). I can't solve the "one screenshot" rebuses without any meaningful description...
- If you use Google-translator to post here - check please what you got before posting it, and edit it before posting. Ask your friends to check it if you don't speak English.
