Hello everyone,
I have a problem on the application of materials, basically I can not set the color on the diffuse channel, both on glossy material that on diffuse material.
I gave the scene to other people who can calmly set everything, so I assume that the problem is not in the scene, but in my system
This problem has started to develop after the last format of my system ... after I reinstalled LW 2015.3 and octane 2:25, I can only see the grayscale colors (white and black included)
The CS in the option panel is set to Linear
Has anyone ever had this problem?
I use windows 10
Thank you
Problem with diffuse channel
I am not complete sure, but I think that the Octane 2.2 plugin has problems with Windows 10 and some of the latest drivers. I have seen reports about this problem before.
Can you please attach an image to see what is your problem, and the scene to render it here and see the difference?
Anyway the only solution could be try an older NVIDIA drivers, if possible.
