License would not deactivate
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
pegot
I had an occurrence where exiting the v3 Octane Server would not deactivate my plugin license on the webpage, as normally happens. I think it was in this state for a few days but I noticed it when I wanted to temporarily use the v2 plugin again.
I also tried clearing my plugin license by clicking on the Activate button with empty credentials from within Blender but that did not work either. Finally, I tried signing out from SA, but the plugin still showed as active on the web site and only prompted me to sign in again when I re-started Octane Server. I did not attempt to activate any v2 apps as I did not want to chance being locked out of either.
The problem appears fixed right now. I believe mojave may have re-set my account as I e-mailed him initially regarding the issue and he suggested I post the problem here.
This occurred on my Mac plugin; I did not try it on Windows.
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
mojave
pegot wrote:I had an occurrence where exiting the v3 Octane Server would not deactivate my plugin license on the webpage, as normally happens. I think it was in this state for a few days but I noticed it when I wanted to temporarily use the v2 plugin again.
This could have happened for a number of reasons, but it is likely is one of these:
- After activating with v2 the deactivation has to be made explicitly as it used to be so the plugin may be holding that license. The case of Mac is a bit special, as v2 and v3 see the machine as a different one (see this) so even though you open and exit the server the license in use by the v2 plugin will not be released as it would think it is used by a different machine.
- If there would be more than one instance of the Octane server running in the background the license would be still in use by it so that could cause that it still in use.
Anyway if this happens again, please send me a PM and I'll help you finding out the exact cause of the issue.
Thank you.
Return to “Bug Reports”
