Since OctaneRender® for 3ds max® v3.03.4 - 4.18 at least, when we plug HDR file in RGB image node instanced in a Sunlight Texture in the compact material editor, 3dsMax doesn't respond anymore.
HDR file in RGB image = freeze 3DsMax
C. RAM Capacity (i.e. 6 GB)
www.jigen.fr
3 x (1 x GTX Titan 6Gb | 2 x Xeon E5-2630 | 32 GO RAM)
- paride4331
Hi guitou,
the right workflow so the HDR is working properly:
plug RGB node (with HDR inside) in the texture of enviroment slot
or
plug Texture Enviroment slot (with rgb image node> with hdr inside)
in 3dsMax environment map slot and uncheck Octane environment
I found no issue about freeze. could you send screenshots to better understand it?
Regards
Paride
or
Regards
Paride
