Hey all,
I'm working with 2 970's and I am trying to understand why I'm getting no change regardless of what is checked on. Right now I'm rendering with none checked. Result 43min. With both checked on I get 43min.
Is this normal? If so, what's the point of even having this feature? I'm baffled! BTW, SLI is disabled.
GPU Config Menu - One or two activated, makes no difference.
Ryan Darling
http://www.RyanDarling3D.com
http://www.Darling3D.com
System Spec's:
Windows 10 64x | i7 - 5820K 3.30Ghz| 2x 970 | 64GB Ram
System Spec's:
hi, there.
Now that looks strange. Haven't You noticed any of cards failing? Enabling 2 cards You' should slice Your rendertimes in half (as Octane scales nearly linearly).
Could You please run OctaneBench with one & then with two cards anabled? What score do You get?
