Material preview crash
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
profbetis
Material preview renders crash when using Mesh UV Projection set to "2". Other sets ie. "1" and "3".
It's less of an instant crash and more of a "takes so long it freezes up the program and makes you think it crashed unless you wait a really long time". If you wait long enough it will eventually finish rendering but be black and not let further materials render.
I get about 5000 lines of this
CUDA error 719 on device 1: unspecified launch failure
CUDA error 719 on device 1: unspecified launch failure  -> failed to clear linear 2D device memory
CUDA error 719 on device 1: unspecified launch failure  -> failed to allocated device memory
device 1: failed to upload data texture 22 of context 1
CUDA error 719 on device 0: unspecified launch failure
CUDA error 719 on device 0: unspecified launch failure  -> failed to clear linear 2D device memory
CUDA error 719 on device 0: unspecified launch failure  -> failed to allocated device memory
device 0: failed to upload data texture 22 of context 1
GTX 1080Ti 11GB (3x), Water-cooled
Intel i7-5820K 6-core @ 3.3GHz
Windows 10 Pro 64-bit, 32GB RAM
paride4331
Hi, profbetis
I verified and reproduced the issue you had.
I will send a file with the issue to developers Octane 3ds max plugin.
Thanks for your contribution.
Regards
Paride
profbetis
Awesome! Great to hear.
Return to “Bug Reports”
