crash when i save image v4.17
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
visionmaster2
crash when i save image from render frame viewport.
dont crash when i save it via the max buffer
rv3d
+1
pixonoid
+1
GPU - 2x Gigabyte GTX1080 8GB + 1x EVGA GTX980 TI sc | CPU - Intel i7-4790K@ 4.0GHz | OS - Windows 10 Pro 64-bit - 32 GB RAM | 3Dsmax - many
paride4331
Hi all,
I'm testing your problem; I tried the test with different scenes, size, beauty passes, passes info, post processing and tone mapping.
I also tried it with different 3ds max versions.
I had the problem you described only in one case: when I rewrite the imagine file.
When I save the image, the problem does not happen, when I rewrite it happens.
Can you kindly take this test and confirm or not?
Paride
rv3d
paride4331 wrote:Hi all,
Paride
No. I try to save as new *.exr file, and octane always crash.
Michaelmong
win 10 64bit,4*gtx1070
paride4331
Hi rv3d,
I can not to crash octane 4:17 at first save.
Can you kindly share a scene with the issue when you save?
If you prefer you can share it in private also.
which version of drivers are you using? which version of 3ds max?
Regards
Paride
Return to “Bug Reports”
