GPU 1 never reaches full power all the time
coilbook
After master crashes or new rendering begins slave on GPU1 never gets to full speed (1400 instead of 1800 mhz). PC must be restarted and then it can happen again 4 hours later. It happened with 780Ti and it is happening with Pascal Titan
It happens on other slaves sometimes too
Octane 2 never had this problem
mauroborba
It's probably because Windows is already allocating some power of GPU 1 for system / monitor.
Win 10 | Geforce GTX980M | i7 4710HQ | 32GB --- (Home Rig - Dominator Pro GT72)
Win 10 | Geforce GTX980ti + GTX970 | i7 5960X | 64GB --- (Studio Rig)
smicha
Have you set priority to low for the first gpu?
Steeviekay
I have the same Problem with my GTX 1070
My 770 runs at 100% - the 1070 just reaches about 85 to 90 % - and never runs in high clock.
For example if i Run GTa5 - the block is 300 MHz higher all the time and the GPU on 100% - so this cant be a Windows problem
smicha
Steeviekay wrote:I have the same Problem with my GTX 1070
Octane never uses as much power as in games.
Steeviekay
Why does my 770 run at 95 to 100 than?
smicha
Different technology. And pascals are not fully optimized yet for Octane.
coilbook
after i restart my PC it goes back to full power, Then rendering for a while GPu1 drops from 1800 to 1400. So it does work at full power just not all the time
smicha
Current support for Pascals shall be better explained by Marcus (abstrax). My 780 and titan never exceed 65-85% of power depending on kernel.
Zay
coilbook wrote:after i restart my PC it goes back to full power, Then rendering for a while GPu1 drops from 1800 to 1400. So it does work at full power just not all the time
Sounds like thermal throttling. Try monitoring the temps.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 560.94| Modo/Blender/ZBrush/Daz/Poser
