Displacement node, doeas it only take a texture node? No mix texture node?
Another thing, is there no more updates for the 2x version?
Displacement
C. RAM Capacity (i.e. 6 GB)
Hello
- paride4331
Hi KilaD,
the non-functioning about displacement map with mix texture is not a bug.
displacement map works with individual RGB images. it works with octane render SA as octane 3ds max plugin.
I'd like to remind you can use the displacement map in the mix material to act on several materials simultaneously.
Regards
Paride
Regards
Paride
