OctaneRender™ for Blender 3.03.4 - 10.2 Linux [OBSOLETE]
This is a TEST version. It may have some bugs, please don't use it for production. Please report the bugs in a Bug Reports section of Blender forum.
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
After the server is run - you can start rendering (or open a rendered view) from inside Blender. Before the very first rendering you should fill in the server address.
  • Fixed a bug: communicating with a server (OSX and Linux only were affected).
  • Fixed a bug: render layers were not rendered correctly for non-global meshes.
You can read about new features of OctaneRender™ 3.0 here:
viewtopic.php?f=33&t=51679
Installation:
- If you need to run the OctaneServer - run it as daemon:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v10.2 Linux
DEMO is available..
Blender Octane Edition DEMO - v10.2 Linux
If you need to see the changelog of current rendering core, or download standalone installer to get network slave and daemon please find it here:
viewtopic.php?f=24&t=56093
Please, if you decided to report a bug:
- Don't post in Blender section the reports about how Octane engine works - use the Octane Standalone forum sections for that.
- Give a meaningful description about what you think is wrong and how to reproduce it (in addition to screenshots if any). I can't solve the "one screenshot" rebuses without any meaningful description...
- If you use Google-translator to post here - check please what you got before posting it, and edit it before posting. Ask your friends to check it if you don't speak English.
