"setting octane materials...."
Jorgensen
when i apply an octane material to the scene - "setting octane materials" is announced and then i takes for ever?
is there a special clever way to add materials to avoid this?
thanks
jorgensen
azen
I have been unable to duplicate your issue. Please confirm the plugin version in use, and the steps you are taking. What kind of materials are you using? Does the material apply eventually or does it not apply at all?
Jorgensen
hi azen
i can't reproduce the issue here at home - i might be caused by a large model, and when i add a glass material like "glass fake falloff".
sketchup does get back to life...
i don't think you should use time on this issue. probably model related.
jorgensen
azen
Thanks for bringing this issue to our attention. If this becomes an issues again down the line, please let us know.
Jorgensen
hmm the problem still exists - if i add a octane material to a smoothed face (800 faces) it takes for ever.
but if i ad the material to the group it's fast.
/bo
azen
Jorgensen wrote:hmm the problem still exists - if i add a octane material to a smoothed face (800 faces) it takes for ever.
/bo
This could possibly tie into a solution that is currently in progress. I will make a note to add this use case to testing to confirm that it has been resolved.
Jorgensen
hi azen
any plans on relasing a update / fix any soon?
thanks
jorgensen
azen
Jorgensen wrote:hi azen
thanks
jorgensen
The next release is currently being tested, and should be released soon - hopefully tomorrow at the latest
alex.b.odowd
Hi!
To inform the developers, I'm using the latest release but this problem persists. The material does eventually apply but it takes 1-3 minute to apply. Obviously makes it hard to test things out.
martinch
Azen I think you posted a response in the wrong post.
Wasnt this about materials?
Your reply is for "skatter render only" post?
Martin
Octane SE + SketchUP / WIN 10 / i7 5930k 3.5 / 64gb / 3x980ti
www.architechtour.com
Return to “SketchUp”
