Hi everyone.
Can you tell me please, did Octane let instance (place) geometry in the poins?
I've a lot places where I need to place geometry but I can't do it manualy. It's very hard to do it manualy.
In modo it calls Replicators.
Fast placement reference objects in geometry.
Win 8.1/64 | Geforce GTX780TI | Core I7 970 | 24GB
- Phantom107
Do you mean you want to place around models, but not inside your main scene because it makes it cluttered and too heavy?
Phantom Scatter can be a solution for you here, it designed entirely around instancing: http://scatter.phantomtechnology.nl/
Developer of tools for Octane:
Phantom Scatter - Phantom Node Link - Phantom Photo Match - Phantom Architecture
I'd like export polygons or vertex as placement geometry to octane and use as positions for copy geometry.
- Phantom107
Yes I got that covered, I called it PER TRI-scatter mode. Essentially it creates an instance for every triangle:
I use it myself to place objects like cars and hedges in my architectural models, but you can use the data to place around any kind of model ofcourse.
Model your scene --> in Phantom Scatter just configure which triangles need to create instances --> export data --> use instancing *.CSV file for instancing in Octane
Hope that solves your problem
Is it possible didm't use other 3d software? Just way to simply expott geometry to scatter?
Marvez yes please with Blender.
I7 5820K 16MB RAM SSD850PRO GTX 970/780
Marvez thank you!Marvez wrote:http://www.blendernation.com/2016/09/11/crowdmaster-v1-1-1-released/
