Error loading plugin in maya ! HELP
MaaYaa
Good day !
Installed maya 2017 with OctaneRender_for_Maya_3.03.2_-_8.02_Demo
seems it's not even loading
gives error message
// Error: line 1: Unable to dynamically load : C:/Program Files/Autodesk/Maya2017/bin/plug-ins/OctanePlugin.mll
The specified procedure could not be found.
whats might be wrong with that ?
Hi MaaYaa,
it seems that you are not alone on this, I'm not a Maya user, but I'm trying to find an answer to your issue.
I let you know asap.
MaaYaa
bepeg4d wrote:Hi MaaYaa,
OK , Thanks !
Hi
seems that the Octane.dll installed with the demo plugin has a linking problem, however this is not the case with the commercial 3.03.2 plugin installer.
So we have to wait that a new fixed demo is published, sorry.
Have you already tried the previous demo version?
MaaYaa
bepeg4d wrote:Hi
I haven't tried previous 3.03.1
its not for 2017 maya , I can't roll back to maya 2016
I will wait for bug fix ((
P.S.
I don't understand that , some people say they can work with octane in maya 2017
well if they can, it means its not something wrong with plugin ... you're saying its something with linking in dll , well in that case that dll should not load no matter who uses it
I think assumption is correct , your demo version and not demo version differs from each other
otherwise I dont understand what is going on here )
I hope that is not in a bug line , its just difference in demo and nondemo
so you just need to recompile demo plugin
well )) hope it will be released sooner than new plugin version comes out
cheers
Hi MaaYaa,
as I said this is not affect the commercial version, only the demo and only with 2017, I'm confident that the issue will be addressed shortly.
Thanks for your patience.
MaaYaa
Thanks for your work
MaaYaa
Please give them an answer (link below) , don't be so irresponsible
where is the maya plugin ... I want to try it
viewtopic.php?f=28&t=53709&start=210
