OctaneRender™ for Blender 2.25 - 9.13 Linux [OBSOLETE]
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Quick fix: improved license activation process. If you send the empty activation login/pass to the render-server, it becomes deactivated.
Installation:
- If you need to run the OctaneServer - run it as daemon:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v9.13 Linux
DEMO is available..
Blender Octane Edition DEMO - v9.13 Linux
viewtopic.php?f=24&t=52329
Please, if you decided to report a bug:
- Don't post here the reports about how Octane engine works - use the Octane Standalone forum sections for that.
- Give a meaningful description about what you think is wrong and how to reproduce it (in addition to screenshots if any). I can't solve the "one screenshot" rebuses without any meaningful description...
- If you use Google-translator to post here - check please what you got before posting it, and edit it before posting. Ask your friends to check it if you don't speak English.
- If you like to discuss something about the plugin - create a separate thread, don't flood in these testing threads please.
Any meaningless or rebus-like "reports" here will be deleted, just to keep the testing threads clean - because these threads are directly used as the source for fixing and improving the plugin.
