OctaneChangePinValue no longer work
formatio
Hi Paul :)
I just upgraded to v3.
I noticed that rhino commands to change pin values no longer work.
Basically I always get the same error:
for example a command lik this: _OctaneChangePinValue maxDiffuseSamples 3
throws an error popup: Error - Could not find pin maxDiffuseSamples.
I check the pin name in the v3 LUA API browser so it should be ok.
Best regards.
Hi. The format has changed.
- Changed OctaneChangePinValue command so the pin to be changed can be embedded in another pin, using the ':' separator. For example "OctaneChangePinValue camera:aperture 5", or "OctaneChangePinValue environment:texture:gamma 1", or "OctaneChangePinValue camera:fstop 3". See https://docs.otoy.com/Rhino/?page_id=711 for details.
formatio
Works like a charm!
Mac
Return to “Rhinoceros 3D”
