Animation sequence failed
hellomono
Hi. I have gtx 780ti 9 I instaled fresh drivers) , cinema 4d 15 and can not render all animation. Sometimes stop after 5 frames, smetimes 20 - lottery..
I even tryed render animation from http://www.beeple-crap.com/ but there was the same problem.
Please help me becouse I am going bo mad ;((( :cry: .
octane 3.03.3 160829 161556.log
(66.04 KiB) Downloaded 172 times
31.07_log.rtf
(51.28 KiB) Downloaded 167 times
slepy8
I have the same issue.
It just randomly stops rendering.
Sometimes after 30 frames, sometimes after 3000. There is no rule here.
GPUs just drop down to 0% but looks like the render continues (clock is moving forward).
I reported it to Aoktar but he couldn't find any issue.
I render lot's of animations so I just decided to set up e-mail temperature alert when the temperature on GPU drops so low, that it's sure that render has collapsed.
Couldn't find any better solution so far. But it's annoying as hell...
hellomono
Thank you for answer.
oh God. Wht a nasty sofware :((( so no chance to fix it? or Do I have buy new graphic card?
slepy8
I used to use 780Ti for my viewport - same issue.
Now I use 980Ti for viewport - same issue.
I was amazed that I'm the only one with the issue but it appears I'm not...
I sense it's something wrong with display driver...
hellomono
so now we are Brothers ;))
But anyway Otoy should refund our money for bad software. I did not have this kind of problem with maxwell, vray or arnold.
Thanks again Bro!
Well i'm back. Could you please point me which scene gives this error?
slepy8
HelloMono - are you using Windows 10?
hellomono
Hi Aoktar.
For example this scene https://vimeo.com/165286507
and I am sending log from this scene. Hope you will find solution for me ;)
I am using windows 7.
thank you,
Woytek
octane 3.03.3 160830 145551.log
(163.75 KiB) Downloaded 166 times
hellomono wrote:Hi Aoktar.
thank you,
Woytek
When you check log you'll see Cuda errors. These are not directly related with plugin but more deep errors. They can be related with Renderer/Cuda/driver or hardware side. Other renderers you said all are cpu based. And don't have much dependencies which can cause extra problems. All is done in one environment(CPU).
I'll try to reproduce the issue. But cannot give any guarantee that will happen on my system. Because lot of differences on every PC. We'll see....
hellomono
Fingers crossed.
Thank you,
Woytek
