Smooth problem
scratch33
I have a problem with glossy surface. When I try to render a bottle, the rendering of the glass is pixelised. Why
I have a image mapfor environment. I have tested with very high image resolution but don't wotks.
Can you help me please. I use lightwave for modeling and setup scene.
Here is the render result
GeoPappas
scratch33 wrote: I have a problem with glossy surface. When I try to render a bottle, the rendering of the glass is pixelised. Why
The easiest solution might be to turn on smoothing in Lightwave and then reload the mesh into Octane.
Otherwise, you will need to increase the number of vertices in the mesh by either adding more vertices manually or subdividing the mesh.
scratch33
Thank you for your reply.
The smooth is on in lightwave.
I have tryed to do a high poly object... actualy the . obj as 219000 poly... this is a little much for a bottle no?
I have tryed to export from modo and it works. But I don't want to use modo for this project. I don't understand what is happening...
