Volume Fog not showing up in Render
Heelie
Hey Guys!
I hope someone can help me with this. I have set up a volume fog and it works fine in the Live Viewport. If I then render it out to the picture Viewer the Volume fog doesnt show up.
The render settings are identical. What could cause this problem??
Hi Heelie,
what are your render settings?
Have you choose Octane as render engine?
What about the geometry engine mode?
Heelie
Hey Beppe!
Geometry Enigne is on Only resend updated Objects - Auto detect
Octane is chosen as render engine
still not working
besides that I have default path tracing settings, nothing special
I unchecked overriding render settings in the global render settings so the Picture Viewer is using the same settings as the Live Viewer.
Are you on latest builds?
Heelie
It works now. I was on a VDB volume with the main tzpe set to generator, wich obviously does not work in the picture viewer.
The Volume Fog Object with the same settings then showed up in the picture viewer.
