Octane for Softimage 1.04 RC5 Demo/Full [Obsolete]
Autodesk Softimage XSI (Developed by Face)
face
Next try to get the renderer working.
face
This version is updated, please reload it again.
FIXED:
  • Logging output to console in non interactive rendering doesn´t work.
  • Extern deformed meshes aren´t updated.
  • octane.dat problems.
DOWNLOADS
MANUAL
INSTALLATION INSTRUCTIONS
  • Please follow the installation instructions in the on-line manual.
NVIDIA DRIVER REQUIREMENTS
  • This version requires video driver 337.xx or higher.
http://vimeo.com/user2509578
abeoctane
Thanks for the update face. :)
face
abeoctane wrote:Thanks for the update face. :)
Hope it works
abeoctane
Hi face, I had the chance to test this version today and Im still getting black renders with this one, the renders with this version are different, you can see some objects and others not while everything is black.
face
abeoctane wrote:Hi face, I had the chance to test this version today and Im still getting black renders with this one, the renders with this version are different, you can see some objects and others not while everything is black.
Hm, thats realy wired.
I edit the Addon file in a text editor to change some pathes, maybe if i save it, some values are different...
Must check it.
face
The working rc3 has used a fixed gamma, the rc4+ has used a variable gamma, maybe this was the problem.
Have updated this version, please try to load and install it again.
abeoctane
Hi face, stills render most of the scene black, RC4 with the lastest .dat renders fine.
face
Ups, my error thought it would be the right one.
Return to “Autodesk Softimage XSI”
