SLI | Standalone - NO / Plugin - YES | i'm confused
pixonoid
Can anyone explain why SLI 1080 's works in 3DS Max plugin but not in the Standalone
i verified the renderspeeds and its currently identical in Sli as in NON-SLI (dirver settings) inside the plugin in 3DS Max
and secondly even IF i disable SLI in the driver (leaving the bridge installed) i stillg et the error inside the Standalone and can't render in it
sample scene (some diamonds)
1 gpu 53s
2 gpu 35s
all while SLI is enabled
Windows 10 64bit v.1607 Build 14393.51
Nvidia Driver 372.54
2x Gigabyte G1 1080GTX
Octane Standalone 3.02
3DS Max 15/16/17 Renderer v.3.03.3 - 4.16
GPU - 2x Gigabyte GTX1080 8GB + 1x EVGA GTX980 TI sc | CPU - Intel i7-4790K@ 4.0GHz | OS - Windows 10 Pro 64-bit - 32 GB RAM | 3Dsmax - many
Hi pixonoid,
the Standalone version that are you using is simply too old for your Pascal GPU. Please could you try again with the latest version?
pixonoid
thank you so much, somehow iw as unable to find the latest version of the standalone
