Request: Rotate Env in LV kotkeys
chupinsky27
After jumping around into substance designer/painter and also quixel, I love that I can interactively rotate the environment using Shift+LMB (restricted to the x rotation). I find myself instinctively trying to rotate the environment using this shortcut in the LV yet having to dive back trough my object manager and tweaking those settings in the tag. Its a lot of clicking just to get to that setting. I have not idea if that would be difficult to implement but I would love that kind of functionality if it's possible.
Also, while thinking of it... maybe this idea could be extended into the daylight environment to control the Rotation + Height of the sun. Maybe use Shift+RMB for the height?
Anyhow, thought I'd make that suggestion to see if it was possible/desired by other users.
-Craig
C4D R17 | c4doctane v3 beta 2.1 | 2x980ti 2x780ti watercooled | Windows10 | 64GB ram
It's not a matter to add in plugin. But hardness is to inject that to workflow in proper ways without making things more complex.
