Сместите кнопку региона!
Elvissuperstar007
смените местами , регион кнопку и рандом габарит .. Вам надо поработать хоть раз над проектом)) что-бы заместо региона постоянно нажимать эту злощастную кнопку габаритов рендеринга, они блин сбивают с толку любого внешне одинаковые. В стенделон версии все грамотно сделали
azen
Hey,
Apologies for the belated response.
First of all, are one of the GPUs involved in your render also being used as a Display card? In that case, Additional overhead will be applied by 3ds Max, taxing your GPU. This will be more noticeable than in the past, if you have had this setup for some time. This is due to the more memory-intensive nature of Standalone. Without the overheads applied by 3ds Max, the standalone will naturally return a faster result.
The best way to avoid this would be to dedicate one card to display, excluding it from rendering. This has always been a recommended setup, but now it will be more critical to abide by this than before, given how V3 works.
Hope this helps.
Return to “User Requests”
