Octane rendering nothing?
greg.thoman
I don't understand what's happened...
I was rendering 4096*4096 just fine and every once in a while it doesn't render anything. I'm not sure why this happens. It loads the data to the cards, but there is no activity.
Any thoughts?
AMD Phenom II X6 3.2 || 12 GB DDR3
GTX 480 1.5GB X 3 Liquid Cooled
RaidMax 1000W PSU || Corsair 850W PSU
MSI NF890-G65 Mainboard || Windows 7 64 Bit
greg.thoman
I found that it has to do with the alpha channel toggle in the mesh preview kernel. Can someone explain this? :?
abstrax
greg.thoman wrote:I found that it has to do with the alpha channel toggle in the mesh preview kernel. Can someone explain this? :?
Is it possible, that you run out of memory? The film buffer with an additional alpha channel requires more memory. Does that also happen at lower resolutions?
Marcus
greg.thoman
I see. I was taking into account the film buffer, but didn't put any thought into the additional alpha channel. I wasn't even intending on rendering with alpha, it was enabled for some reason.
Thanks for your insight!
