Net rendering crash (another)
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
sdanaher
3.03.2 R5
Network rendering
LV
Render region active
Changed the source or an instance in a scene
no change to render, click Refresh...crash
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
Can we keep similar posts in same topic? We're looking that. Thx.
sdanaher
I was asked before to put different ones in a different post. From my POV its crashing for a different reason.
Please, I'm not a beta tester - make it easier to report and track bugs...
Sure nobody is beta tester. But all seems(at least 3 post with NETRENDER) related with netrender. And we'll look it.
Seperated threads are just making harder and confusing to track and answer. Also please post bugs in bugreports section with bugreport.zip if you want to help us.
Thanks!
sdanaher
Correct, we're users: paid for the software. I'm doing 20x more bug reporting with octane than any other sw I use.
Otoy needs to invest more in a simple bug reporting system, rather than expecting users to do a lot of the leg work. You guys need to make it easier for us, not the other way round.
sdanaher wrote:Correct, we're users: paid for the software. I'm doing 20x more bug reporting with octane than any other sw I use.
It's not so easy and don't know better way. Plugin is build in middle of lot of layers. C4D SDK and Octane Renderer SDK. Also Octane is build on Cuda API. And networking is another layer. Sometimes it's impossible for me to catch exact points due this isolated parts.
At least posting a BUGREPORT.ZIP and scene with latest step will help to understand where to look.
abstrax
I just fixed a deadlock in the net render master which seems to occur only on OSX. It happens when a message was being sent at the same time when some new render data arrived and the master cancelled the current update messages. Hopefully this will solve the issue above.
EDIT: After re-reading your opening post, It will probably not fix it. I will try to reproduce the problem.
abstrax
sdanaher wrote:3.03.2 R5
Network rendering
LV
Ok, I tried to reproduce your problem without any luck. I very quickly run into the problem that the network rendering stops and C4D doesn't wants to quit / crashes during shutdown, but I couldn't make it crash just by clicking refresh in live viewer. The net render hang will be fixed with the next Octane release.
sdanaher
It just happened again. It was when changing the linked object in a cinema instance while LV was active.
abstrax
sdanaher wrote:It just happened again. It was when changing the linked object in a cinema instance while LV was active.
I tried again, but had no luck. Maybe wait until 3.03.3 is out and if the problem still occurs, please send me the C4D scene and the last steps you did until it crashed. Thanks.
Return to “Bug Reports”
