Octane crashes Cinema on quit
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
sdanaher
As title. If LV is active when you quit, Cinema beachballs.
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
Are you on 3.03.2-R4?
sdanaher
Yes
Can you give a better info?
1- For every scenes always or sometimes?
2- Do you use netrender?
3- Do you have another plugins?
4- When do you close that? While some export or material preview in progress?
sdanaher
aoktar wrote:Can you give a better info?
1- always (tried a simple scene with 2 objects and an ENV light), provided LV is active, it hangs. No materials.
2- yes
3- lots, none active at the time (see 1)
4- just when LV is active. If I Stop it (R button) it doesn't hang on quit.
I've fixed a hang problem on latest build and working fine on windows until now. Try without netrender and let me know result. Also try without any other plugins and let me know again.
sdanaher
aoktar wrote:I've fixed a hang problem on latest build and working fine on windows until now. Try without netrender and let me know result. Also try without any other plugins and let me know again.
Ahmet, I can only report issues as the crop in the corse of my work up in the hope they'll get fixed. I try to provide as much info as I can given my time constraints but I have enough to do already working around crashes and other issues. I need network rendering to be ON....
When you say its working fine on Windows, can you confirm its also working fine on OSX with network slaves on your end?
None of the plugins I use regularly crash cinema.
Hi sdanaher,
we can reproduce the issue with Mac master, but there is the same behavior also with Standalone, so the issue is not plugin related.
We have already informed the devs and we let you know asap,
thanks for your patience.
sdanaher
bepeg4d wrote:Hi sdanaher,
Great. Lets hope for a fix very soon.
I'm not sure if its related but I've also had some new random crashes of a different kind than usual: cinema quits, no beach ball, no error message, gone. Pretty sure its when Network in on. Moving a light, or sometimes simply resending the render data causes it.
sdanaher wrote: I'm not sure if its related but I've also had some new random crashes of a different kind than usual: cinema quits, no beach ball, no error message, gone. Pretty sure its when Network in on. Moving a light, or sometimes simply resending the render data causes it.
Are you exactly be sure that you use 3.03.2-R4 on OSX? Because crashing while moving something(with NET), this should be fixed. Latest build has been done for this.
Can you test it without netrender and give us better information? It's important to know where to look. Pls.
Return to “Bug Reports”
