Hi, I noticed when I was trying to bind the settings to a slider in Lightwave (like I have done before) that no matter what it was set to. No change appeared in Octane.
At the same time Octane can see there was a change, because it updates immediately. But it ignores the new values. So I tried again with changing values directly in Octane itself, and that worked fine.
Attaching to the slider again.. all works. But.. again, it doesn't update the input from the sliders. I have to press 'redraw' every time for it to actually register the change. Despite it recognizing that there is a change in the scene, and redrawing itself.
So it is the manual 'having to click on redraw' I am wondering about. It seems to me that it misses the new values for some reason? Because previously, it worked fine. Is this related to the problems with GTX 1080?
Problem with slider values not being updated
I tried similar thing i.e. make Null that would control the rotation of Octane Environment map. Only updates on Reload/Redraw in IPR. Even enabling 'Reload every 10 frames' has no effect.
I think that is because Octane cannot use any native LW info realtime, like when you add an object, you need to do Reload before it shows. Any info that LW generates at render time is not available to Octane, that is why Octane fakes the procedural by generating image from it on the fly.
Someone please correct if I am wrong but this is how I think it goes
Antti
Antti
AMD Ryzen Threadripper 2990wx (32c/64t),64GB RAM,NVIDIA GTX 1080ti,Win10
Clarisse 4,Houdini 18 (+Octane 2019),Blender2.81,Fusion360,Onyx,ZBrush,SubstPnt...
Started: Houdini 2019, Clarisse 2016
No business, just fun
Can you send to me a sample scene with this behavior to test it here?MichaelT wrote:Hi, I noticed when I was trying to bind the settings to a slider in Lightwave (like I have done before) that no matter what it was set to. No change appeared in Octane.
This problem is very simple to find out.
You can adjust the Octane Light's and set the light's power with envelop let the light turn on or turn off slowly.this problem will happen.
Recenetly I want to do this kind of animation. but found the envelop not work.I need to redraw it every frame.If I render it in frame 10.Octane will use frame 10's light power value to render other frame.
If I render it in frame 50,Octane will use frame 50's light power value to render other frame.I've tried many times but can't find any way to solve this problem. -_-|||
