Magog wrote:Hi Necko!
In Si I work with Si unit (1 Si unit = 10 cm).
In the PPG Octane Export, the mesh unit is on the cm, instead, on octan property the unit is a default, meter to meter.
I've tried another way, to export the obj file and import to Octane but the result is the same.
tnx for your reply!!
i export from archicad to blender (when i do it i have to resize it in blender, i scale up model 100 times up) then in blender i export from meters.
In octane i have selected meteres and everything works great. Can you send me that model. I could import it in blender and try. You can export it as 3ds and upload it to some share service or if file is smaller you can send it to
[email protected]
I had similar problems last night only cos i had wrong units selected in octane. Point is to mach scale in octane like it is in your 3d modeler aplication.
try to put cm in octane
u can try with simplier scene, sraw box, texture it and try different scale (meters, cm, mm...)
if problem persisit then some other problem that could be
