I’m having an issue with the dirt map and getting it to show the way I want when I adjust the scale of the geometry.
In the (good/green) image you will see that at roughly 200cm the dirt map is showing up (the way I want) but then when I scale the object down to 2cm (20mm) I cannot get the dirt map to look the same no matter how much I play around with the dirtmap sliders?? I’ve tried every combination for the past hour trying to get them to look the same but can’t?
Any guidance/solutions would be very much appreciated.
Thanks!
Dirt Map Scaling issue?
Have you tried to scale radius too?
https://docs.otoy.com/#60Dirt%20Texture%20map
