Lighting in a Small Room
Moderator: BK
Hydra
I recently picked up this;
https://www.renderosity.com/mod/bcs/pop-art-pad/116035/
Which I quite like, but sadly its just not lit at all. If the supplied lights were actually used, no one would live there since its dark and dingy. (Why do designers do this?)
So does anyone have any tips on how to light a small room? Should I be considering simple HDRI?
Intel i7-4790K, Asus Z97-A, Corsair 32GB DDR3 1866MHz CL9, 2XAsus STRIX GTX980 DirectCU II OC 4GB, 4XSamsung 840 EVO Raid 10, Win 7 x64 Pro.
I don't have that prop, but if you don't mind slower render times, I would try changing the light cover material to be a diffuse material emitter.
DrHemulen
You could also try to make the walls not cast shadows as in the tutorial here: viewtopic.php?f=44&t=51514
Then you can just use sunlight, HDRI or encapsulate your scene in a sphere of light as the light will go right through the walls.
GTX 780, 6 gigs of VRAM - Win 7 Home Premium 64 bits
Return to “DAZ Studio”
