MAterials V2 to V3
lylo
Hello everybody
Is there a solution to use materials V2 in V3?
Thanks you
Lylo
azen
Just to clarify, what version of the v2 plugin do you use?
Curcis
Hi, i have exactly the same question since i have install the 3.02 - 3.17 version, all my old sceen and material are white.
I can open a matlibs (bibliotheque), but eatch time i put the material in the matereial navigator, it is white!
If y try to use 3dsmax 2016 whith 2.25 - 2.21 release, that's the same! That's not working anymore.
does i have to remake all the textures with the N°3 realease?
Best regard
and sorry for my english, i'm french.
I have ask the same question at the hotline, if i get a solution, i will tell you!
coilbook
not sure why otoy does not have an automatic converter, You guys can convert vray materials to version 2 or 3 but you cannot convert your own native old materials (version v2.23.2 - 1.9 or bellow ) to version 3.
Curcis
Exact, no way to do it!
I run 3dsmax 2016 whith an older version of Octane and 3dsmax 2017 whith V3, and i do my texture again comparing the two materials editor windows.
Long work, but its working....
Good luck.
Return to “Autodesk 3Ds Max”
